A stable indoor environment helps maintain the lifelike effect. Avoid exposing your
sex dolls to excessive heat, direct sunlight, or humidity. These environmental controls don't require constant attention—just be mindful and place it properly. A stable environment helps maintain the stability of the materials.
Having supplies prepared in advance simplifies daily care. A small care kit containing approved cleaners, soft cloths, talcum powder (if needed), and a protective cover helps encourage regular use. Easy access translates intention into action. Having a
sex doll storage case makes daily care even easier.
